  3. "Hidden" parameters in Pcell
  • Subscribers 150
  • Views 3743
RVERP
RVERP over 13 years ago
 When I generate a Pcell using a function and it's arguments, my pcells do not generate correctly.
 I understand why, once the pcell is compiled, he has unknown variables, the one that where passed by the function.  IfI replace this variables with a parameter of the pcell, the functions arguments are stored and the pcell compiles.
I don't want to use variables for this to prevent having a long list.
Is there another way of doing this, some sort of hidden parameter or property?
So this doesn't work:
procedure( makeAcell(arg1 arg2)
pcDefinePcell(
w = arg1*arg2
This does work, but it's not what I want:
;PCELL PARAMETERS
((Arg1 int arg1) (Arg2 int arg2))
    The problem is that the variables arg1 and arg2 are out of scope when the body of the pcell is evaluated. You might think that you could solve this with SKILL++ (which has lexical scoping), but pcDefinePCell is not supported in SKILL++ (it can call SKILL++ functions, but can't be used in SKILL++ - mainly because the pcell wouldn't be able to store information about the lexical environment in which it was called). One way is to store the arguments on the cellView somewhere (as properties say), but another might just be to do:
    procedure(makeACell(arg1 arg2)
    eval(`pcDefinePCell(
      w=,arg1*,arg2
    ) ;pcDefinePCell
    ) ; eval
    ) ; procedure
    The quote before the pcDefinePCell is a backquote. This means that the code is not evaluated - but a list of the code - but rather than a normal quote, backquote allows selective evaluation. You precede the variable with a comma to selectively evaluate it.
    To illustrate what I mean:
    val1=20
    val2=30
    lst=`(a b ,val1 c ,val2)
    then lst will contain (a b 20 c 30)
  • RVERP
    Ok, thanks, this seems to work, with one exception.  If I use backquotes in a for loop, this doesn't seem to work.
     example:
      w=,arg1*,arg2
    for( n 1 ,arg1
    do something
    ) ;for
    ) ;pcDefinePCell
    ) ; eval
    ) ; procedure
    It looks like that he still needs the arg1 in the for loop.
  • RVERP
     I tried something in the ciw, if I enter:
    y=1
    and then:
     '(x ,y z)
    I still get:
    (x y z)            I expected (x 1 z)
    What's wrong here??
  • berndfi
    berndfi over 13 years ago
     The way you build your list is worng if you want y to be evaluated do it that way
    list(y)
  • RVERP
     In the example I want to build a list with x y z, where only y is evaluated.  This should be the way to do it (it's exactly the same example as in the cadence manual, only I have a different outcome as in the manual.)
    In your first example, this code worked perfectly:
      list(ddGetObj("BBDlib") "mypcell" "layout")
        (myp 1)
      w=,arg1*,arg2
      for( n 1 ,arg1
        fprintf(stderr "w is %L, n is %L\n" w n)
      ) ;for
     ) ;pcDefinePCell
    ) ; eval
    ) ; procedure
    It output this when the pcell evaluated:
    makeACell(3 4)
    Generating Pcell for 'mypcell layout'.
    w is 12, n is 1
    w is 12, n is 2
    w is 12, n is 3
    As for the second case, it's because you have the wrong quotation mark. It should be a backquote not a normal single quote. So ` not '
    Check your pcell code in case you've used the wrong quote. Normal single quote prevents evaluation completely, whereas backquote allows selective evaluation when expressions are preceded by comma.
