  3. What is the difference between ~> and ->
  • Views 7356
howardhaoracle
howardhaoracle over 13 years ago
Hi..
Please explain the difference between using ~> and ->  ?? When do you use ~>  or ->?
I looked at some Skill codes and I see both are used
 Thanks for your explanation..
Howard
  • skillUser
    skillUser over 13 years ago
     Hi Howard,
    The basic answer is that "~>" should be used for database objects (and CDF, techfiles, constraints...) whereas the "->" operator is for "everything else" such as windows, menu structures, form structures, disembodied property lists, tables etc.  Often they can be used interchangeably but with one big difference: the ~> operator can handle a list on its left hand side (input) and expand the query for each of the elements on the left.  Here's a brief example:
    cv = geGetEditCellView()
    cv~>nets
    => (db:0x16fcba12 db:0x16fcba13 db:0x16fcba14 db:0x16fcba15 ...)
    cv~>nets~>name
    => ("Out" "net9" "A" "vss!" "B" ...)
    In the example the second ~> (in red) has a list as its input and it queries the "name" attribute for each of the members and returns the list of results.  If you tried "->" for the second query ("name") it will return nil, but if you used it for the "cv~>nets" query it would work since there is only one thing in its input on the left.
    Hopefully this clarifies the main differences.  Generally speaking you should use the "~>" for database objects, techfile access, constraint object access and so on, and use "->" for everything else.
    Lawrence.
    What Lawrence says is not strictly correct. Actually you can use the -> and ~> interchangeably except on lists, where they behave differently. With a list, if you use -> then you are treating the list as a disembodied property list where you have a list with a dummy value first (often nil) followed by key/value pairs where the key is a symbol. So for example:
    dpl=list(nil)
    dpl->colour="red"
    dpl->shape="circle"
    then:
     > dpl
    (nil shape "circle" colour "red")
    > dpl->shape
    "circle"
    > dpl->shape="square"
    "square"
    > dpl->shape
    "square"
    > dpl
    (nil shape "square" colour "red")
    If you use ~> on a list, then it effectively does a foreach mapcar over the list, applying the ~> operator on each member of the list and returning a list of the results. This is as Lawrence mentioned above. So doing:
    cv~>nets~>name
    is like doing:
    foreach(mapcar net cv~>nets net~>name)
    but obviously shorter and more to the point.
    So ~> can be used for windows, menu structures, form structures, tables and so on - just not disembodied property lists.
    Regards (and sorry to be pedantic!),
