  3. How to parse a string in skill?
  • Replies 7
  • Views 24807
Sandeep4386
Sandeep4386 over 13 years ago
I want to parse a string and rename it.
e.g. I would like to check for a cell name, and if there is an hyphen(-) in a cell name, I would like to convert it to an underscore(_).
so if a cell name is 'create-gds'  I want to convert it to 'create_gds'. Any help would be appreciated.
-Sandeep
  • dmay
    dmay over 13 years ago
    Here is one way:
    s="create-gds"
    when(rexMatchp("-" s)
        rexCompile("-")
        s=rexReplace(s "_" 0)
    Derek
    Sandeep,
    In IC61, you can do:
    ; only need to compile the pattern once
    hyphen=pcreCompile("-")
    ; then any time you need to do the replace, can reference the pattern object in var hyphen
    cellName="create-gds"
    newCell=pcreReplace(hyphen cellName "_" 0)
    In IC61 and IC5141 you can use the less powerful rex functions (but the compiled pattern will get overwritten if it is used elsewhere since it only has a single compiled pattern at once):
    rexCompile("-")
    newCell=rexReplace(cellName "_" 0)
    The pcre functions have a much richer pattern matching syntax - see the PCRE web site for more details.
  • marcelpreda
    marcelpreda over 13 years ago
     Hi *,
    My feeling is that for char substitution the most safe,simple, fast way is to use buildString() and parseString() procedures.
    myCellName = "create-gds-2"
    myCellName = buildString(parseString(myCellName "-") "_")
    "create_gds_2"
    BR,
    Marcel
    Marcel,
    Actually I'd go for a regular expression approach. If you have multiple occurrences of the delimiter, or leading or trailing delimiters, it won't work properly. For example:
    myCellName="-hello-world--test"
    "hello_world_test"
    Kind Regards,
  • Sandeep4386
    Thank you everyone. rexReplace worked perfectly.
  • RFStuff
    RFStuff over 13 years ago
     Dear Andrew,
    This type of replacement happens where ? Is it in the Schematic viewer or in the Created Netlist or in the Layout Editor ?
    Kind Regards,
    I don't understand your question. This post is about doing pattern replacement in SKILL, so it's nothing to do with a particular application.
