  3. Skill API to update references post rename
  • Views 14959
skohli
skohli over 13 years ago
Is there a way to update references when view is renamed using custom Design Management operation. I do not want ccpRename to perform rename on design objects rather use the DM's rename functionality hence post DM rename the object with old name will cease to exist. Now can I update existing references if any?
  • skillUser
    skillUser over 13 years ago
    I think that you would have to create your own updater if you are not using the ccpCopy/ccpRename etc. functionality - it is part of the cdsCopyShell, look in the documentation for "Creating a Cross-Reference Updater" - I'm not sure if you can just update the references without performing a copy or rename though, you will have to look into that.
    Hope this helps.
    Lawrence.
