  3. naming of dummy instances
  • Subscribers 150
  • Views 15427
Malcolmw
Malcolmw over 13 years ago
Greetings Forum, 1st time poster :
I have been using this code to rename my dummy instances which works fine the first time I use this but subsequent runs report that "DUMMY0" already exists.  How to modify this to remember where it left off last time?
One idea I had was parsing the current cellview with
zz=geGetEditCellView()
then: parsing that list with  zz~>instances~>names to find "DUMMY(x)" and then start at last x+1 value.
 procedure( nameDummyInst()
   let((cv cnt instList)
     cv=geGetWindowCellView()
     instList=selectedSet()
     labelLayer = list("text" "drawing")
     cnt = 0; initialize CNT
     foreach(inst instList
        temp1=pcExprToString( cnt )
        newInstName=strcat( "DUMMY",temp1 )
        inst~>baseName=newInstName
        cnt++;
        ) ;foreach
      ) ;let
) ;procedure
Thanks in advance
Malcolm
  • marcelpreda
    marcelpreda over 13 years ago
     Hi Malcom,
    I guess that you can use dbFindAnyInstByName(cv instName)
    If the instance name already exists, then try next name.
    something like:
            newInstName=strcat("DUMMY" pcExprToString(cnt++))
            while( dbFindAnyInstByName(cv newInstName)
             );; while
    ) ;foreach
    BR,
    Marcel
  • Malcolmw
     Greetings Marcel - thank you very much for your help.  I tested the new code and works wonderfully.
    Malcolm
