  3. How to get the union box of the selected objects ?
  • Views 15938
Charley Chen
Charley Chen over 13 years ago
 Dear All  ,
 I see the command 'dbUnionBBox' , but can't launch ,
Or how to use it ( 'dbUnionBBox' ).
Thank you,
Charley
  • skillUser
    skillUser over 13 years ago
    Hi Charley,
    This is because the command you are referring to is a C API in the ITK manual, not a SKILL API.   It should not be too hard to write, however the documentation has a general example:
    procedure( trBBoxUnion( bBoxList )
        let( ( llxList llyList
            urxList     uryList
            minllx      minlly
            maxurx      maxury
            llxList = foreach( mapcar bBox bBoxList
                xCoord( lowerLeft( bBox )))
            llyList = foreach( mapcar bBox bBoxList
                yCoord( lowerLeft( bBox )))
            urxList = foreach( mapcar bBox bBoxList
                xCoord( upperRight( bBox )))
            uryList = foreach( mapcar bBox bBoxList
                yCoord( upperRight( bBox )))
            minllx = apply( 'min llxList )
            minlly = apply( 'min llyList )
            maxurx = apply( 'max urxList )
            maxury = apply( 'max uryList )
            list( minllx:minlly maxurx:maxury )
        ) ; let
    ) ; procedure
    I would recommend that a different name is used for the procedure, say CCFbBoxUnion() (Cadence CIC Forum...). This should answer your question I think.
    Best regards,
    Lawrence.
  • Charley Chen
     Dear Lawrence ,
     Thank you for help .
    Charley
  • Charley Chen
     Dear Lawrence
    It can get the union bbox.
    But if I want to get the surrounded edge of all select objects? (e.g. polygon points)
    How can I do it ?
    Thank you.
    Charley
    Charley,
    It sounds as if you're after something like the convex hull - this was discussed in another thread.
