  3. How to avoid metal1 routing on device in VCAR
  • Views 14679
Sarvani
Sarvani over 13 years ago
 Hi All,
When I am using VCAR for routing then I got metal1 layers on devices. But i don't want it. Could you please let me know solution for this?
I am getting single via in routing. But I need double vias in routing.
And I would like to avoid poly routing layout. Please suggest me.(My version is 6.1.5)
 Thank you,
Sarvani
    Sarvani,
    Presumably you could define some kind of keep out - your question is a bit vague.
    As for the double vias, that has been covered before in this forum (use the Community Search for "double via vcar" - there are a few relevant posts - here's one though:
    /forums/p/20336/1301070.aspx#1301070
