  3. Find form name
  • Views 15508
Find form name
psill00
psill00 over 13 years ago
I have a script that sets the value of a path width through the leHiCreatePath() command. However the form name sometimes changes. Ex le0PathForm, le1PathForm, ...
How do I find the name of the form for a command?
    leGetTechFormList(techGetTechFile(geGetEditCellView()))->pathForm
    will return the path form object, and the name you can get with:
    leGetTechFormList(techGetTechFile(geGetEditCellView()))->pathForm->hiFormSym
    The leGetTechFormList() returns a disembodied property list of forms which are technology dependent - so need to have different settings for different windows.
    You may also be able to avoid interacting the form by doing:
    leSetEnv("pathWidth" 2.34)
    but it may seed the width based on the minWidth of the layer being used (the first time). I can't remember...
    p, li { white-space: pre-wrap; }
  • psill00
     Thanks for the info.
