  3. Selecting Instance one after other
  • Replies 9
  • Views 20258
Neeraj Vardhan
Neeraj Vardhan over 13 years ago
I would like to select instances in a specific order and save the order. I want to use a bindkey which will help me select both in schematic or in layout to select instances in a specific order.
 Regards
Neeraj
  • Neeraj Vardhan
    I was thinking if there is any method, that i can select instance in a particular order and save there db and width and length information, in required sequence.
    Regards
    Neeraj
    The Forum Guidelines tell you not to cross-post in multiple forums, so please don't do that.
    It's not that clear what you want - but can't you just do shift-left mouse click to add onto the selection one at a time, and then geGetSelSet() will return the objects in the order you want. If you want to get info about the selected instances, you could do:
    geGetSelSet()~>w
    or if you wanted to get the instance name, w and l properties, you could do:
    instInfo=foreach(mapcar inst geGetSelSet() list(inst~>name inst~>w inst~>l))
    In my case, that returns:
    (("NM11" "1.2u" "280n")
        ("NM10" "1.2u" "280n")
        ("NM7" "1.2u" "280n")
        ("NM6" "1.2u" "280n")
    which was the order I selected them in.
  • Neeraj Vardhan
    I had this in my mind, but what i want is same bindkey for both schematic and layout.
    ex : hiSetBindkey("Layout" "<key>s" "function()") & hiSetBindkey("Schematic" "<key>s" "function()")
    so that i dont have to use different bindkeys for layout and schematic.
    Regards
    Neeraj Vardhan
    Hi Neeraj,
    OK, so you know how to select things sequentially, you know how to print out information from the selected set, and you know how to define a bindkey - it's not clear (to me at least) what you still need to know?
    A clear question is much more likely to result in a clear answer, I'm afraid.
  • Neeraj Vardhan
    I was using the name "Schematic" instead of "Schematics" in the bindkey. That was the reason, procedure was not working for my Schematic window.
    I have one more question
    1. How to pass CDF parameters from shcematic to layout.
     Regards
    Neeraj
    Neeraj,
    deGetViewType() will tell you "schematic" or "maskLayout", or hiGetAppType(hiGetCurrentWindow()) will return the same prefix as used for bindkey registration (i.e. "Schematics" or "Layout").
    I'm not sure what you mean by your second (now first, since you've edited your post) question. What are you trying to do?
  • Neeraj Vardhan
    Actually i got the first one by "view=cvID~>viewName". So i edited the post, sorry. Is there any way i could inform about the editing done.
    Actually my second problem is, i want to call the instance selected in schematic to layout. So i wanted to access the CDF parameters and copy them to layout window.
    Regards
    Neeraj
    Neeraj,
    How about dbCopyProp()? This will then allow you to copy all the instance properties from one instance to another (e.g the schematic instance to your new layout instance).
    As for editing the post, there's no way to send a notifier other than posting a new append. Don't worry though... I should have checked before I started typing!
  • Neeraj Vardhan
    Thanks Andrew, I would keep in mind while posting this. Regards Neeraj Vardhan
