  3. Extracting name of instance in Layout XL
  • Subscribers 148
  • Views 15989
Neeraj Vardhan
Neeraj Vardhan over 13 years ago
I had a question, which is not related to the topic.
I was trying to extract name of instance from layout XL, and every instnace has a " | " in starting eg. "|M1". Now when i was trying to save the name as inst~>name, it saves as " "|M1" ", i.e with quotation. Is there a way to convert this string to symbol. i need just |M1.
i had a case where the inst name was " "|M1.1" " also.
Regards
Neeraj
    Neeraj,
    If it is not related to the topic, you should really create a new thread (as the Forum Guidelines tell you to do). So I split it into a new thread to avoid confusion.
    I don't understand - are you saying that the instance names have embedded quotation marks? That sounds very odd, and I've not seen that before.
    You can of course convert a string to a symbol (e.g. with stringToSymbol() ), but I somehow doubt you really want to do that.
  • hwxu
    hwxu over 13 years ago
    I think the "ParseString()" would be helpful.
  • hwxu
    here is a skill code ,maybe it will help you.
    /*Synopsis : CreateXL_Label()
    Version : 1.0
    Create Date : 2007-09-13
    Author : Justin Wang
    E-Mail : justin727@gmail.com
    hiSetBindKey("Layout" "Ctrl<Key>l" "CreateXL_Label()")
    procedure(CreateXL_Label()
    prog((winId cvId Shapes Layer shp Box llx lly urx ury Text)
    winId = hiGetCurrentWindow()
    cvId = getEditRep(winId)
    Shapes = geGetSelSet(cvId)
    Layer = list("TEXT" "drawing")
    foreach(shp Shapes
    if((shp~>objType == "inst" ) then
    Box = shp~>bBox
    llx = car(car(Box))
    lly = cadr(car(Box))
    urx = car(cadr(Box))
    ury = cadr(cadr(Box))
    Text = car(parseString(shp~>name))
    ; example:   |M36.1 ---> |M36.1
    ;Text = car(parseString(shp~>name "|"))
    ;Text = car(parseString(shp~>name "|."))
    ; example:  |M36.1 ---> M36
    if((urx-llx < ury-lly)
    then
    dbCreateLabel(cvId Layer (llx+urx)/2:(lly+ury)/2
    Text "centerCenter" "R90" "stick"  (ury-11y)/10 )
    else
    Text "centerCenter" "R0" "stick"   (urx-llx)/10 )
    );if
    );if
    );foreach
    );prog
    );procedure
