  3. How to create a library/cell browser form?
  • Views 3487
xuli230
xuli230 over 13 years ago
I created a form with three string fields and a button, a string field is used to input library name
anohter string field is used to input cell name, the other one is used to fill view name,
How can I invoke the library/cell browser when I press the button, then I can fill the three string fields
by mouse choosing in library/cell browser ( like create instance in layout edit window)
    See the example in this previous post.
  • xuli230
    Thanks! I know how to write my code now, your code is very helpful!
    By the way, which document intrduce the form package style?
    your form package code:
     hiCreateAppForm(
        ?name 'oferExampleForm
        ?formTitle "Ofer's example form"
        ?fields
    list(
        list(templateFile 0:0 600:30 200)
        list(templateLoad 100:5 45:20)
        list(templateSave 150:5 45:20)
        list(sep1 0:35 600:0)
        list(libName 0:40 600:30 200)
        list(cellName 0:70 600:30 200)
        list(viewName 0:100 600:30 200)
        list(browse 200:130 100:25)
        list(sep2 0:165 600:0)
        list(radio 0:190 600:0 200)
        list(sep3 0:205 600:0)
        list(userData 200:220 100:25)
    If you search in cdnshelp for "hiCreateAppForm" you'll find both the definition and a section labelled "Two Dimensional Form Layout". Both of these are in <ICinstDir>/doc/skuiref/skuiref.pdf in the Forms chapter.
  • xuli230
    Got it! Thank you very much!
