  3. deRegUserTriggers works only part of the time
  • Views 15530
TauStudent
TauStudent over 13 years ago
Hi, im using deRegUserTriggers to run a skill procedure after a cell is opened
deRegUserTriggers("maskLayout" nil nil 'lg_PostInstallTrigger)
my lg_PostInstallTrigger run properly if i open the cell with "Layout L"
but doesn't run if i open with "Layout XL" , "Layout GXL" , "Layout CE"
 can anyone tell me why is that ?, and how can i make it run for all four (and only for them) ?
Thanks !
    You need to register your triggers for "maskLayoutXL", "maskLayoutGXL" and "maskLayoutCE" as well in order for them to work in these other applications.
    With the layout window the current window, if you type deGetViewType() in the CIW it will tell you the view type of the window, so you'll know what to register the trigger under.
  • TauStudent
    It's working !, Thanks :)
