  3. cdsvias problems
  • Replies 8
  • Subscribers 150
  • Views 18772
cdsvias problems
fuelectronics
fuelectronics over 13 years ago
 Dear all,
I try to creat the vias in my own PDK,  so i goes to technology file manger to creat cdsvias.
After that i return back to  Virtuoso layout editting, to press "O", it shows   NO CONTACTS/VIAS defined in constraint group.
I check the "Help", I should go to window>>contraint group manger for my vias defination, but i did not find this option in there.
Do you have any idea to sovle this problem, let me get the required VIAS in the contraint group.
  • berndfi
    berndfi over 13 years ago
     Maybe a stupid question, but have you loaded the modified techfile back into the techlibray?
  • fuelectronics
     I load it, it does not work. They are not defined in my cotraint group.
  • skillUser
    skillUser over 13 years ago
    Have you put these vias in the validVias section of the interconnect section of the constraint group (virtuosoDefaultSetup I think, though you may need to add them to other CG's also).
    Lawrence.
  • fuelectronics
     no, thanks.
    Do you know how to do it ?
  • fuelectronics
     Thanks for your reply, i try to give the inputs as you mentioned above.
    It does not help, the same problem still exsits. Another solution will be welcomed.
    I think the chances of being able to help you are small without seeing what you've actually done.
    Maybe customer support would be your best bet?
  • fuelectronics
    Sorry to ask so detailed questions, it is really helpful to know how to build a PDK for a beginner.
    I have solved the last problem by accepting the suggestion. I can see the vias option when i press "o" in the editor. But I try to put the vias into the layout editor, they are not visable (or empty).
    I check the other technology PDK, it always has a "via" view in the library. For example, named M1_M2 with "via" view.
    I donot have such cells in my library, I try to produce them by creating CDSvia in the technology file manger, but they are in the view of "layout"
    Did I miss some tech layer rules in there ?
    The problem is that you're not providing enough detail, so it's very hard to know what's wrong.
    That's why I suggested customer support, as that way Cadence support can take a look at your data.
    Kindest Regards,
