  3. Question Regarding Exporting Parametric Sweeps
  • Views 14617
EonkernYang
EonkernYang over 13 years ago
Hi All,
 I am trying to export a series of nested parametric sweeps in Cadence. Using ocnPrint, the data is separated into sections according to the values of the outer sweep variables, but I would like to have a "flattened" output, where each sweep vector is in an adjacent column, rather than in a new subsection.
for example it is currently doing:
VTD_n = -3.000e-01
VTD_p             -3.000e-01        0.000e+00         3.000e-01
 0.0000e+00        9.9708e-01        9.9638e-01        9.9400e-01
 1.0000e-02        9.9638e-01        9.9548e-01        9.9235e-01
 2.0000e-02        9.9561e-01        9.9448e-01        9.9042e-01
VTD_n = 0.000e+00
 0.0000e+00        1.0000e+00        1.0000e+00        1.0000e+00
 1.0000e-02        1.0000e+00        1.0000e+00        9.9999e-01
 2.0000e-02        1.0000e+00        1.0000e+00        9.9999e-01
and I would like it to do:
VTD_n            -3.000e-01      -3.000e-01       -3.000e-01                0.000e+00           0.000e+00      0.000e+00
VTD_p             -3.000e-01        0.000e+00         3.000e-01             -3.000e-01        0.000e+00         3.000e-01
 0.0000e+00        1.0000e+00        1.0000e+00       1.0000e+00        1.0000e+00        1.0000e+00        9.9999e-01
 1.0000e-02        1.0000e+00        1.0000e+00        9.9999e-01        1.0000e+00        1.0000e+00        9.9999e-01
 2.0000e-02        1.0000e+00        1.0000e+00        9.9999e-01      1.0000e+00        1.0000e+00        9.9999e-01
    You could probably write something to expand the family waveform objects yourself, but I suggest you contact customer support - this seems a reasonable enhancement request to me.
    Kind Regards,
