  3. letGetContactRule(), leGetContactParam(), letGetContactNameArray...
  • Views 14639
letGetContactRule(), leGetContactParam(), letGetContactNameArray() in IC615?
danmc
danmc over 13 years ago
Are there equivalents of these functions in IC615?  I have some custom code which was developed in IC5 that uses these functions to get information like via width/height/rows/columns, etc.
-Dan
    Dan,
    Not direct equivalents, but assuming you have a variable tfId with the techFile id in, you can do:
    leGetContactNameArray:   tfId~>viaDefs~>name
    leGetContactParam: not really a direct replacement - you can look at the code in this post to see how to mess with the parameters of a via and find the values of a via instance.
    leGetContactRule: as above
    The problem is that vias are very differently handled in OA compared with CDB (in CDB they were just instances, whereas vias in OA are separate objects, and don't require (for standard vias) a cellView master to represent them).
    It might be best to contact customer support so that we can look at your custom code and advise how best to adapt it for IC615?
