  3. How to transform a rod Object?
  • Views 15841
Neeraj Vardhan
Neeraj Vardhan over 13 years ago
I want to modify the orientation of a rod Object keeping its bBox unchanged. Is there any function such as dbsetq for rod objects? using which i can tranform the properties of rod.
Regards
Neeraj
    You can transform the master object - i.e. the rodId~>dbId - but whether it does what you want is another matter ;-)
