  3. Reading a parametrized cdf parameter
  • Views 22040
kglaros
kglaros over 13 years ago
I am trying to read the CDF parameters of a FET.
My problem is that some of them refer to other CDF parameters via iPar().
So if I do: p1=cdfGetInstCDF(inst)~>parameters
v1=car(parameters)~>value
Then I get v1="iPar("\width\")", instead of the numerical value.
This is fair enough and expected, but I was wondering if there is an easy way to get the evaluated value of the parameter returned rather than the string?
I could write a function to do this iterating through the parameters, but I am currently extracting the values of several parameters via lists (setof) and so if there is a built-in function to do this it would be more convenient.
Thanks for the help.
Kostas
  • skillUser
    skillUser over 13 years ago
    Hi Kostas,
    I haven't got time to look into the details but I think you need the aelEnv* functions such as aelEnvInterpret, aelEnvCompile and aelEnvExecute .  I may be off the mark, but this might be a good place to start looking... There are a few posts that mention at least one of these functions.
    Lawrence.
    This code will do what you want. Ifyou know the instance ID, and the parameter name (e.g. it is called "dc" or whatever) do: abIPar("dc" car(geGetSelSet()))
    /* abIPar.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Aug 28, 2003
    Modified
    By
    Function that can be used in an opParamExprList()
    CDF setup to get an instance's parameter value.
    Note, this is not the _simulated_ value necessarily...
    SCCS Info: @(#) abIPar.il 07/01/08.21:14:26 1.3
    (procedure (abIPar paramName @optional (inst ilInst) (slot 'value))
      (let (env lineage session cdf unevaluated evaluated compiled top)
           (setq top (geGetTopLevelCellView))
           (getWarn)
           (unless top (error "Can't find parameter %s" paramName))
           ; Get the original parameter value
           (setq cdf (cdfGetInstCDF inst))
           (setq unevaluated (get (get cdf (concat paramName)) slot))
           ; If it is a string, evaluate it as an AEL expression
           (if (stringp unevaluated)
               (progn
                (setq env (aelEnvCreate "f"))
                ; set the path down to this element
                (setq lineage (append1 (reverse
                                        (mapcar 'car (geGetHierMemInst)))
                                       top))
                (setq lineage (cons inst lineage))
                (aelSetLineage env lineage)
                ; Get the current session
                (setq session (asiGetSession (hiGetCurrentWindow)))
                ; define all the global variables
                (foreach designVar
                         (or (and session (asiGetDesignVarList session))
                             (artGetCellViewDesignVarList top))
                         (aelEnvSetGlobals env (car designVar) (cadr designVar))
                ; Evaluate the expression
                (if (or (null unevaluated)
                        (equal unevaluated ""))
                    (setq evaluated 0.0)
                    (progn
                     (setq compiled (aelEnvCompile env unevaluated))
                     (if compiled
                         (setq evaluated (aelNumber (aelEnvExecute compiled)))
                         (progn
                          (printf "*ERROR* %s " (aelEnvGetErrStr))
                          (setq evaluated nil)))
                evaluated
               ; Otherwise, if not a string, return it as it is
               unevaluated
  • kglaros
    Thanks for the help. They were both spot on! Unfortunately I have been using dbOpen functions instead of editor functions (ge), and so I don't have the hierarchy readily available. Found a lazy workaround for what I wanted to do though. Thanks again! Kostas
    Kostas,
    The ge stuff is only really needed to compute the "lineage" (i.e. the hierarchical path down to this occurrence), which is only needed if you want to be able to cope with pPar() evaluation too. If you can generate the lineage another way, or don't care about pPar() evaluation, you can effectively omit the bit which sets the lineage, or set it to be something basic.
