  3. Using for loop inside hiCreateAppForm fields
  • Replies 10
  • Views 18788
Sandeep4386
Sandeep4386 over 13 years ago
I am encountering an error while using a for loop inside hiCreateAppForm fields. Here is the error message:
*Error* hiCreateAppForm: not all fields have 2D attributes specified, and/or illegal attribute values
However if I comment out the for loop then error goes away.
hiCreateAppForm(
?name 'Form
?formTitle "test form"
?fields
list(
       list(label 0:0 600:30 200)
list(all 10:30 600:30 20)
list(none 10:60 600:30 20)
list(cellviewFrame 0:90 600:30 200)
for(i 1 count
  list(cellview[i] 10:90+(i*30) 600:30 20)
);for
      );list
);hi createAppForm
hiDisplayForm(Form)
Any help would be appreciated.
P.S. cellview has been declared as an arry in earlier part of the code (declare(cellview[2]) )
Sandeep
  • skillUser
    skillUser over 13 years ago
    Hi Sandeep,
    The issue is that for just returns t. I think that you may want something more like foreach mapcar (this is assuming that "cellview" contains a field that hiCreateAppForm can use), in combination with linRg to create a list of numbers to iterate over:
    hiCreateAppForm(
       ?name 'Form
       ?fields
         list(
           foreach(mapcar i linRg(1 count 1)
           );foreach mapcar
         );list
    );hiCreateAppForm
    hiDisplayForm(Form)
    Hopefully this willsolve the problem.
    Lawrence.
  • Sandeep4386
    Hi Lawrence,
    Thank you for your response. I tried using foreach along linRg but it still gives out the same error. Plus, you are right, "cellview" does contain fields that can be used by hiCreateAppForm
    Sandeep
    Sandeep,
    The code as Lawrence posted it won't work because it would not be a correctly structured list - for a 2D form you need a list of sublists, and what you would have got is a list of sublists for the first four fields, and then a sublist containing sublists for each cellView.
    So you'd need something like this:
    hiCreateAppForm(
       ?name 'Form
       ?fields
         append(
    list( list(label 0:0 600:30 200) list(all 10:30 600:30 20) list(none 10:60 600:30 20) list(cellviewFrame 0:90 600:30 200)
    ) foreach(mapcar i linRg(1 count 1) list(cellview[i] 10:90+(i*30) 600:30 20) );foreach mapcar );append );hiCreateAppForm
  • Sandeep4386
    Thanks Andrew, that worked perfectly. One more question, I was trying one more alternative but that din't work, would you be able to tell what's wrong with method below:
    ButtonList=append1(ButtonList cellview[count])
    hiCreateAppForm(
           ?name 'Form
         ?fields append(
                           list(
                               list(all 10:20 600:30 20)
       list(none 10:40 600:30 20)
                               list(cellviewFrame 0:70 600:40+(count*30) 200)
                             );list
                            ButtonList
                   );append
    );hi createAppForm
    Sandeep
    Sandeep,
    Probably because ButtonList is just a list of the fields, not a list of lists (where each sublist is the field plus coordinate info). The ?fields argument can either be a simple list of fields, or a list of the 2D attributes, but you can't mix the two together, which is what you're doing here.
  • Sandeep4386
    Thanks Andrew, That makes sense.
  • Sandeep4386
    Now I'm running with one more problem. I want to pass my array/table to different function and then access its fields, How do I do that? This is what I tried but din't work.
    procedure(allCB(cellview count)
       let((Form)
        Form=hiGetCurrentForm()
    foreach( key cellview
                 Form->cellview[key]->value=t
        ;a=getq( get(checkNsaveForm arrayref(cellview key)) value) ;Form->cellview[key]->value=t
        ;println(a)
       );let
    );procedure
    This errors out with the message: *Error* arrayref: can't handle nil[1]
  • skillUser
    Hi Sandeep,
    Apologies for the earlier mistake, I did not test the code...  For this latest, you will most likely need to use get again and putprop/putpropq, something like the following (again, not tested, so apologies if it still fails):
      let((Form)
           putpropq(get(Form cellview[key]) t value)
        ;println(a)
      );let
    );procedure
    Hope this works for you,
    Lawrence.
    If I've understood your previous examples, the cellview array contains the field structures, not the field names. In which case you'd do:
    get(Form cellview[key]->hiFieldSym)->value=t
  • Sandeep4386
    Thanks Lawrence and Andrew.
    get(Form cellview[key]->hiFieldSym)->value=t  worked perfectly.
    I will keep posting here in case of further problems. appreciate your help.
    Sandeep
