  3. symbols of my pcell nmos/pmos transistors
  • Views 3663
fuelectronics
fuelectronics over 13 years ago
Dear all,
I created my required pcell layouts of the pmos/nmos transistors, but i also need to produce the symbols for them.
So i easily copy the standard symbols from "analogLib" library to my own library.
When I try to simulate my schematic using these two symbols, the spectre simulator complains :
Error found by spectre during hierarchy flattening.
    ERROR (CMI-2116): M0: Too few terminals given (0 < 4).
I CHECK the schmatic netlist and found there are NO terminals for my transistors.
Do you have any good idea to solve this error ?
    Did you also copy the cell property bag (data.dm in IC61, prop.xx in IC51)? This contains the CDF for the cell. Also, did you copy the spectre (stopping view) for the transistors too?
    Having fixed this, you may need to do a netlist->recreate.
  • fuelectronics
     Yes, i copy all of them and recreate the netlist, but the transistors do not have their terminals (s,d and g) in the netlist.
    Can you tar up your example and attach it (using the Options tab when replying) so that I can take a look?
  • fuelectronics
     Thanks, the problem is solved by defining the simulator (in CDF form) for the transistors.
