  3. Problem with create Auto Via option.
  • Views 13523
2221
2221 over 12 years ago
Hi All,
I am using Cadence tool IC6.1.5 version . In the technology library there are different types of vias like (M2_M1a, M2_M1_FBD,M2_M1_PBD, etc,.) .  If I use auto contact between M2 and M1 with option under Via Definition as "M2_M1_FBD" or "M2_M1_PBD". It will place the via with via Definition as "M2_M1_FBD" or "M2_M1_PBD" , but has the parameters as Minimum Rules which is for "M2_M1a" .
I want the selected vias with corresponding Viasdefs not the minimum rule parameters.
Please tell me how to overcome this issue.
Thanks ,
srinivas
    Please contact customer support. We'd really need to see your technology data (the tech file at least) to properly understand your issue.
