  3. Filter Path from Selected set of shapes
  • Subscribers 150
  • Views 17044
Ajesh Dhanraj
Ajesh Dhanraj over 13 years ago
Hei,
Is there a command to filter paths from a selected set of shapes.
Thanks in advance.
Ajesh
  • marcelpreda
    marcelpreda over 13 years ago
    hi Ajesh,
    you have to look for objType property.
    soemthing like
    my_path_set = setof(x my_fig_set x~>objType == "path")
    BR,
    Marcel
  • Ajesh Dhanraj
    Thanks Marcel, Could you make it a little clear. I have just started self learning on SKILL. Thanks Ajesh.
    Ajesh,
    It might have helped if you were a little clearer as to what you meant by "Filter".
    You might have wanted to just do this (this code will deselect any paths from the shapes selected, which will "filter" them - but I don't know whether that is what you meant by filter).
    foreach(fig geGetSelSet()
      when(fig~>objType geDeselectFig(fig))
    In IC615 you can also use the layer (actually the object palette, I think) to control which types of shapes are selectable.
  • Ajesh Dhanraj
    Thanks Marcel and Andrew,
