  3. How to change fixnum type into a string type
  • Views 18016
Carlsberg
Carlsberg over 13 years ago
Hi everyone!
How can I change a fixnum type (100.00) into a string type (“100.00”) ?
THX !!
    First of all, 100.00 is not a fixnum, it's a flonum. A fixnum is an integer.
    The easiest is to use sprintf though. Either use:
    myreal=100.0
    myint=100
    sprintf(str "%d" myint) => "100"
    sprintf(str "%g" myreal) => "100"
    sprintf(str "%.2f" myreal) => "100.00"
    If you're only interested in the return value, you can pass nil as the first argument rather than the variable name.
  • Carlsberg
    thank you very much!
    And I still have some confusions :
    when I try to combine a flonum(100.00) and a string (“k”),I use the  function:strcat .
    here are some procedure:
    sum=sum+value   ;;both sum and value are flonun type
    mystring=strcat("sum" "k")   ;;;;the function does not work as I think.
    the result  I  expect to see is :mystring="100.00k"
    would you plz help me ?
    thanks
    It sounds as if it would be a very good idea for you to read the SKILL Language User Guide at <ICinstDir>/doc/sklanguser/sklanguser.pdf (can also be found in cdnshelp). I can't see why you would think that doing a strcat of two literal strings would do anything other than concatenate them together - so strcat("sum" "k") would clearly give "sumk" - since "sum" is in quotation marks, it's clearly a literal string, not a variable.
    If you want to get this as a string, you can do:
    sprintf(mystring "%.2fk" sum)
    Or you could have done:
    sprintf(sumAsString "%.2f" sum)
    mystring=strcat(sumAsString "k")
    And by the way, there's no tax on characters in this forum. English is my first language, so I rather like "please" being spelt correctly rather than an SMS-style abbreviation. It's one of those things I'm picky about, sorry...
  • skillUser
    skillUser over 13 years ago
    You could use the function aelSuffixWithUnits() to take the value and the units and produce a formatted result, for example:
    aelSuffixWithUnits("100.00" "k")
    => "100 k"
    OR print it with formatting (in this case "print" it to a string variable):
    sprintf(mystring "%g k" sum)
    => "100 k"
    The benefit of the aelSuffixWithUnits() function is that it can accept a floating point number or a string for its input.  You can control the decimal places etc. by modifying the format specifier '%g'
    Lawrence.
  • Carlsberg
    I am new to skill.And I am sorry about that.I will keep it in mind..
    thank you !
  • Carlsberg
    thank you
