  3. SKILL code to parameterize a property(e.g. w,l) of an instance...
  • Views 1524
SKILL code to parameterize a property(e.g. w,l) of an instance in schematic which reflects in the netlist
Atul Dwivedi
Atul Dwivedi over 13 years ago
Hi all,
As the subject suggests, I want to insert parameters in a design to run further analisis (with the netlist). For the ease of the user, it is more instructive to somehow insert the parameters at the schematic level and get those parameters in the netlist ((IC6.1.5.500.132).
I have done the following progress till now :
selectedObject=geGetSelSet()
selectedObject~>w="1.00*param1" ;;;;1.00 is mandatory scaling factor
However, this approach is not always working. While doing "check and save", I do get many errors of some parameters getting out of range (not the ones I have perturbed). Can anyone else suggest a more elegant and safe approach?
Atul
  • theopaone
    theopaone over 13 years ago
     Hi Atul
    Can you explain what you are doing better?
    Where does param1 get set?
    Is w a CDF parameter on the instance masters and what is its type?
    Can you give examples of the errors your getting with C&S ?
     Ted
  • Atul Dwivedi
    Hi Ted, Thanks for taking interest in such an old thread. However I recently realized that the errors which I was getting were due to some mistake in my script itself which I overlooked earlier. 'w' is the CDF parameter denoting width of MOS. param1 gets a value in the netlist. I add a few lines like .param param1=10u at the end before launching the simulator. The above approach selObj~>w="1*param1" is working perfectly fine for me now, except for the warning while netlisting: "param1 not set". (the catch was perhaps 'w' is a float, but is stored as a string!) Anyways, thanks for taking interest. Regards, Atul
