  3. Error when creating newlibrary
  • Views 16722
wgtkan
wgtkan over 13 years ago
Unable to create library “Name” dd CreateLib: newly created library not found using normal search rules perhaps “.” Isn’t the first entry ‘in force’ setup.loc file(?)
Every time I try to create a new library under IBM PDK menus  --à library àcreate -à in New Library window I put the name of the new library and attach it to the existing technology file, I get an error message saying:
How do I fix it.
    Hard to tell with your slightly scrambled message above. Where is your "setup.loc" file? (type "cdswhich setup.loc" in the terminal window that you started virtuoso? And what is the contents?
  • wgtkan
     When I typecdswhichsetup.loc I get a response that says nil
    That's because you typed "cdswhichsetup.loc" (without a space) in the CIW, and not
      cdswhich setup.loc
    in the terminal window that you started virtuoso in (i.e. not the CIW), which is what I suggested you do.
