  3. Making 'reload' work on custom expressions in plot wind...
  • Subscribers 148
  • Views 2339
Making 'reload' work on custom expressions in plot window
FormerMember
FormerMember over 13 years ago
 I created a form to help plot analog waveforms as busses in the plot (Visualization) window. When I reload it after a new simulation, I get a warning and an error:
*WARNING* Symbol(s) named " 'expr_19' " used in the definition of dependent expression  'expr_19'
 have not been defined as expressions. This may result in evaluation errors or ambiguous values for the dependent expression.
 Either add these symbol(s) as expression(s) in the Outputs or remove them from the definition of the dependent expression.
expression evaluation failed: val is not legal.
"(\"eval\" 0 t nil (\"*Error* eval: unbound variable\" expr_19))"
Do I need to make this a calculator function for it to reload?
Here's the code:
; 5/14/2013 T. Spargo
; Form for the tasCreateBus procedure.
; Takes analog waveforms and creates a bus out of them.
hiCreateAppForm(
 ?name 'tasCreateBusForm
 ?formTitle "Create Bus"
 ?callback "tasCreateBusCB()"
 ?fields list(
  list(hiCreateStringField(
   ?name 'busName
   ?prompt "Bus name"
   ?value "")
   0:10 250:30 110
  list(hiCreateButton(
   ?name 'selectNet
   ?callback "tasCreateButtonCB()"
   ?buttonText "Select bus")
   260:10 70:30 110
   ?name 'plotName
   ?prompt "Plot name"
   ?value "")
   0:50 300:30 110
  list(hiCreateIntField(
   ?name 'bitStart
   ?prompt "First bit"
   ?value 7)
   0:90 150:30 110
   ?name 'bitEnd
   ?prompt "Last bit"
   ?value 0)
   0:130 150:30 110
  list(hiCreateFloatField(
   ?name 'vt
   ?prompt "Threshold voltage"
   ?value 2.38)
   0:170 200:30 110
  list(hiCreateRadioField(
   ?name 'radix
   ?prompt "Radix to use"
   ?value "Hex"
   ?choices '("Binary" "Octal" "Hex" "Decimal") )
   0:210 320:30 110
; tasCreateBusForm->busName->hiToolTip = "Name of the net or bus"
; tasName2BusList.il
; Given a wire name, bit range, and Vt, it creates a list of digital
; signals that can be passed to awvCreateBus.
; tasName2BusList("/I0/DQ_buff" 63 32 2.38)
procedure( tasName2BusList(name upperBit lowerBit Vt)
 let( (bit n2BL bitStr nameStr a2D inst)
 n2BL = list()
 inst = geGetInstHier()
 for( bit lowerBit upperBit
  bitStr = sprintf(nil "%d" bit)
  nameStr = strcat(inst "/" name "<" bitStr ">")
  if( debug printf("tasName2BusList: nameStr = %s\n" nameStr) )
  a2D = awvAnalog2Digital(VT( nameStr) nil nil  Vt  1 "centre")
  if( debug printf("tasName2BusList: a2D = %L\n" a2D))
  n2BL = cons(a2D n2BL)
 n2BL
; Create a bus from analog bits.
procedure( tasCreateBusCB()
 let( (winNum busName plotName upperBit lowerBit Vt radix wvBus)
 busName = tasCreateBusForm->busName->value
 plotName= tasCreateBusForm->plotName->value
 upperBit = tasCreateBusForm->bitStart->value
 lowerBit= tasCreateBusForm->bitEnd->value
 Vt = tasCreateBusForm->vt->value
 radix = tasCreateBusForm->radix->value
 if( errset(tasName2BusList(busName upperBit lowerBit Vt)) then
  wvBus = awvCreateBus( plotName tasName2BusList(busName upperBit lowerBit Vt) radix )
 else
  wvBus = awvCreateBus( plotName busName radix )
; wvBus = awvCreateBus( plotName tasName2BusList(busName upperBit lowerBit Vt) radix )
 awvPlotWaveform(awvGetCurrentWindow() list(wvBus))
; Click on a net to select it
procedure( tasCreateButtonCB()
 let( (obj netName)
 geSingleSelectPoint()
 obj = geGetSelectedSet()
 if( debug printf("tasCreateButtonCB: obj = %L\n" obj))
 type = car(obj~>objType)
 if( and(type != "path" type != "line") then
  printf("Not a wire, objType = %L\n" obj~>objType)
 else
  netName = car(obj~>net~>name)
  if( debug printf("tasCreateButtonCB: netName = %s\n" netName))
  netName = car(parseString(netName, "<"))
  tasCreateBusForm->busName->value = netName
debug=t
hiDisplayForm( tasCreateBusForm)
I'm using IC6.1.5-64b.500.12 and simulating in ams (irun64: 12.20-s010).
Tom
    Hi Tom,
    The issue is that awvCreateBus doesn't store the expression on the waveform object, so reload doesn't know how to re-construct the bus. This is probably a bug, and should be reported to customer support.
    However, you can workaround it like this:
     let( (winNum busName plotName upperBit lowerBit Vt radix wvBus listOfBusMembers)
     if( errset(listOfBusMembers=tasName2BusList(busName upperBit lowerBit Vt)) then
      wvBus = awvCreateBus( plotName listOfBusMembers radix )
      ; set the expression attribute on the bus so that it
      drGetWaveformYVec(wvBus)->expression=`awvCreateBus(,plotName
          list(,@foreach(mapcar busMember listOfBusMembers drGetWaveformYVec(busMember)->expression))
          ,radix)
     else
    (the bit with the comment "set the expression attribute on the bus..." is the relevant part). The backquote part is a convenient way of constructing a list which looks like an expression, but stuffing in the relevant content with , and ,@.
  • FormerMember
     Hi Andrew:
     I mostly follow what you're trying to do. There were a couple missing parens that I added, hopefully in the correct places. When I try to use it, I get an "eval: unbound variable - plotName" error. I don't understand the details enough to fix this.
    I don't understand the ->BLOCK EXPRESSION part- what is that? (NOTE FROM MODERATOR: This was an issue with the forum software, and has since been resolved)
    Here's that procedure- it's been simplified a little:
     listOfBusMembers = tasName2BusList(busName upperBit lowerBit Vt t))
     wvBus = awvCreateBus( plotName listOfBusMembers radix)
     ; 'reload' fix from Cadence
     ; Set the expression attribute on the bus so that it remembers how to recreate it.
     drGetWaveformYVec(wvBus)->expression = `awvCreateBus(,plotName
      list(,@foreach(mapcar busMember listOfBusMembers drGetWaveformYVec(busMember)->expression)),
      radix)
    Tom
    Tom,
    No idea what happened - when I pasted the code, something went wrong with the brackets, and I've no idea where the BLOCKED EXPRESSION bit came from (now fixed in the forum software)!
    I'll try pasting it again:
          ,radix)
     else
    Note, I didn't include the simplifications you made - I'll leave you to do that.
