  3. Via symbolic variables
  • Subscribers 150
  • Views 14825
psill000
psill000 over 13 years ago
I would like to write a skill script modify via symbolics in layout.
Is there a way to output or get the varaible names and values to via symbolics of stdVia and customVia?
Example of variables:
stdVia:
via~>cutColumn, via~>cutRow
customVia:
via~>row, via~>column
 What are some of the other variables the via symbolic within the object
    For stdVias you simply need to know what the available parameter names are - see this other post for an example of where I use a predefined list of parameter names.
    For customVias, they are probably pcells, so the names of the parameters are:
    via~>master~>superMaster~>parameters~>value~>name
