  3. Plotting Y vs Y with OCEAN
  • Views 19048
kitmonisit
kitmonisit over 13 years ago
The following code is the plotting part of my OCEAN script. vds and gmbs are previously defined variables which can be plotted.
win = newWindow()
wv = ocnYvsYplot(?wavex vds ?wavey gmbs)
ocnSetAttrib(?XAxisLabel 'vds ?YAxisLabel 'gmbs ?yNumber 1 ?stripNumber 1)
The Problem:
I get a dialog box titled "ChangeMode", which says "Licence Virtuoso_Visual_Analysis_XL not available. Would you like to run Analog_Design_Environment_L license?". I click Yes.
But now the X and Y axis labels are not what I want them to be. I think the ocnSetAttrib line gets passed over because of the license checkout glitch.
    Try adding:
    envSetVal("wavescan.application" "VIVALicenseCheckoutOrder" 'string "ADE,VIVA")
    to alter the license checkout order for ViVA.
  • kitmonisit
    Thanks, that fixed it.
    One more question: how do I rename the trace label, as seen in the legend rows? At this point it looks like "getData("M0.m1:gmbs" ?results..."
    For example:
    net51=getData("net51" ?result 'tran)
    net25=getData("net25" ?result 'tran)
    drGetWaveformYVec(net51)->expression='net51
    drGetWaveformYVec(net25)->expression='net25
    ocnYvsYplot(?wavex net51 ?wavey net25)
  • huoyunjie
    huoyunjie over 12 years ago
    hi Andrew: I have a question about using ocnYvsYplot(). My cadence version is 5141. I can't use ocnYvsYplot(). When i use ocnHelp(), I can't find ocnYvsYplot(). Can you help me?
    It's in IC5141, at least in the latest hotfix (I didn't go back and check). It's in the documentation, and help(), but not in ocnHelp:
    > help(ocnYvsYplot)
    Loading skillDev.cxt
    Consulting cdsFinder database (may take a while) ...
    ocnYvsYplot([?wavex o_wavex ?wavey o_wavey] [?exprx o_exprx ?expry
    o_expry] [?title l_titleList] [?color l_colorList])
    => wave / nil
    Plots a wave against another wave or an expression against another
    expression.
    t
    I guess as an alternative, you could use this:
    /* abChangeXAxis.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 25, 1999
    Modified   May 21, 2002
    By         A.D.Beckett
    Function to change the X Axis of a waveform to the corresponding
    Y values of the second variable.
    Also function to transpose the X and Y axes of a waveform.
    Now handles families, and can be registered as a special function.
    Just call:
    abRegChangeXAxis()
    to add to the calculator.
    SCCS Info: @(#) abChangeXAxis.il 11/27/08.09:59:36 1.3
    *                    (abChangeXAxis yVar xVar)                     *
    * Return a new waveform object with the x axis set to the y values *
    *                     of the second argument.                      *
    (procedure (abChangeXAxis yVar xVar)
      (let (newWave)
        (cond
          ; Handle normal waveform
          ((drIsWaveform yVar)
           (setq newWave (drCreateEmptyWaveform))
           (drPutWaveformXVec newWave (drGetWaveformYVec xVar))
           (if (eq (drGetWaveformXVec yVar) (drGetWaveformXVec xVar))
             ; if the x axes are the same for both, it's simple
             (drPutWaveformYVec newWave (drGetWaveformYVec yVar))
             ; otherwise need to use value() to interpolate
             (let (xVec yVec len)
               (setq xVec (drGetWaveformXVec xVar))
               (setq len (drVectorLength xVec))
               (setq yVec (drCreateVec (drGetWaveformYType yVar) len))
               (for ind 0 (sub1 len)
                    (drAddElem yVec (value yVar (drGetElem xVec ind)))
               (drPutWaveformYVec newWave yVec)
           newWave
          ; Handle family
          ((famIsFamily yVar)
           (famMap 'abChangeXAxis yVar xVar)
           ) ; is family
          (t
            (error "abChangeXAxis - can't handle %L\n" yVar)
          ) ; cond
        ) ; let
      ) ; defun
    *                         (abRegChangeXAxis)                          *
    * Registers abChangeXAxis as a new special function in the calculator *
    (procedure (abRegChangeXAxis)
      (calRegisterSpecialFunction
        (list "abChangeXAxis" 'abChangeXAxisCB)
      t
    *                            (abChangeXAxisCB)                             *
    * Callback function for the special function - which builds the expression *
    (procedure (abChangeXAxisCB)
      (calSpecialFunctionInput 'abChangeXAxis '(STACK))
    *                     (abTransposeXY var)                      *
    *             Swap the X and Y axes of a variable              *
    (procedure (abTransposeXY var)
      (let (newWave)
           (drPutWaveformXVec newWave (drGetWaveformYVec var))
           (drPutWaveformYVec newWave (drGetWaveformXVec var))
           newWave
