  3. Generate instances from schematic to layout using SKILL
  • Views 16926
TaherKotb
TaherKotb over 13 years ago
Hello
 I have been trying to search for a SKILL command to place the design Instances from schematic to layout in the Layout SKILL reference but i couldn't find it. Could any one please guide me through this problem ?
Taher
    lxGenFromSource(
    d_schCellViewID
    [ ?layLibName t_layLibName ]
    [ ?layCellName t_layCellName ]
    [ ?layViewName t_layViewName ]
    [ ?configLib t_configLib ]
    [ ?configCell t_configCell ]
    [ ?configView t_configView ]
    [ ?initCreateInstances { t | nil } ]
    [ ?initDoStacking { t | nil } ]
    [ ?initDoFolding { t | nil } ]
    [ ?initCreatePins { t | nil } ]
    [ ?initGlobalNetPins { t | nil } ]
    [ ?initCreatePadPins { t | nil } ]
    [ ?initCreateBoundary { t | nil } ]
    [ ?initCreateSnapBoundary { t | nil } ]
    [ ?lxPositionMinSep n_lxPositionMinSep ]
    [ ?lxGenerateInBoundary { t | nil } ]
    [ ?initCreateMTM { t | nil } ]
    [ ?extractAfterGenerateAll { t | nil } ]
    [ ?extractSchematic { t | nil } ]
    [ ?ignoreSchematicCheck { t | nil } ]
    [ ?initPrBoundaryShape t_initPrBoundaryShape ]
    [ ?initPrBoundaryOrigin l_initPrBoundaryOrigin ]
    [ ?initPrBoundaryPoints l_initPrBoundaryPoints ]
    [ ?initAreaSource1 t_initAreaSource1 ]
    [ ?initAreaSource1Val n_initAreaSource1Val ]
    [ ?initAreaSource2 t_initAreaSource2 ]
    [ ?initAreaSource2Val n_initAreaSource2Val ]
         => dbCellViewID
    Generates a layout from a specified schematic cellview. If you do not specify the layout library, cell, and view names, the layout view is created with the same name as the schematic cell. If you do not specify the physConfig library, cell and view names, the layout view is created with the same name as the layout cell with physConfig as the default physConfigView. If you use the optional arguments, they override the existing environment variables set in your .cdsenv file.
  • TaherKotb
