  3. About the deleteWaveform() command in OCEAN script
  • Subscribers 148
  • Views 14803
winever
winever over 13 years ago
Hi everybody!
Does anyone know what the "x_index" refer to in the OCEAN command deleteWaveform( {x_index | all_string} ) ? The OCEAN Reference said it is a integer identifying a particular waveform curve. But what is it? How can I get the integer? I am still confused. I tried the window number, but got an error message undefined entity - 1. I appreciate it for your help.
Winever.
    It's the order in which the waveforms were defined - although this might depend on the version you're using (and if IC5141 whether you are using AWD or wavescan) - it rather helps if you say.
    I can do:
    awvGetWaveNameList(currentWindow())
    and I get:
    ((1 3 4 5 6)
        ("/CLK" "HOLD_TEST" "/INM" "/INP" "/OUTM")
    (I've already deleted waveform 2)
    If I want to delete HOLD_TEST, I do:
    deleteWaveform(3)
    The numbers in the first list correspond to the second list names. I did this in IC615.
    Hope that helps,
  • winever
    You are right, Andrew. Thank you so much. I really appreciate it.
    Best regards,
    Winever.
