  3. How to find instances connected to specific pin
  • Views 19643
narendra046
narendra046 over 13 years ago
Hi All,
In my schematic, test<0:10> pin is there. I need which instances(instance id's) connected to test<3> net.
It will be useful me in some other scricpts. Please help me on this by skill code.
Thanks in Advance,
Narendra
    Navendra,
    I don't have any code to do this to hand, but if you can use IC616, you can probe the net using the probe command in the schematic editor, and then use the probes assistant to see what it is connected to. The Probes Assistant is new in IC616. You can also export a CSV file of everything that it is connected to.
    Probing you can do in any release though.
  • NiallDuncan
    NiallDuncan over 13 years ago
     Hi Navendra,
    You could try something like this:
    targetPinName = "test<3>"
    cvId = geGetEditCellView()
    list_instId = list()
    foreach( instId cvId~>instances
      if( instId~>objType=="inst" && instId~>purpose=="cell" then
        connectionFound = 0
        foreach( connId instId~>conns
          if( connId~>net~>name==targetPinName then
            connectionFound = 1
        if( connectionFound==1 then list_instId=append(list_instId list(instId)) )
  • narendra046
    Hi NiallDuncan,
    Thanks for your response.
    If schematic have pins like, POR, EN, Edge, OT<3> , Test<0:5>.
    Your scricpt will works for only to find instances for POR, EN, Edge, OT<3>. This can't find for Test<3> or Test<2> etc.
    As per your basic thought, I modified this to work perfectly is--
    reqinstlist=nil
    targetpinname="Test<3>"
    cvId=geGetEditCellView()
    foreach(instId cvId~>instances
    if(instId~>objType=="inst" && instId~>purpose=="cell" then
    kk = nil
    kk1 = nil
    conn_names=nil
    conn_names = instId~>conns~>net~>name
    foreach(conn_name conn_names
    index= length(parseString(conn_name "<"))
    if(index >= 2 then
    kk = dbProduceMemName(conn_name)
    kk1=append(kk kk1)
    conn_names = remove(conn_name conn_names)
    conn_names = append(conn_names kk1)
    when(conn_name==targetpinname
    reqinstlist=cons(instId reqinstlist)
    Thank you
    Narendra
  • SRNAYAK
    SRNAYAK over 11 years ago
    hi andrew,
             i was searching for a skill code that will
        ---- that will search all input and output pin/ports of a schematic .. and then checks each pins/ports are conneced to an instance (antenna diode) or not ?
           ( ex ::-- if a schematic have 10 inputs then each should have an anteenna diode in schematic .....if not flag message while check and save)
    --- check an instance (EX :antenna diode) , which is connected to each input and output pins/ports of a schematic..
         ----- if designer forgot to add  antenna diode in any pin .. it should be warned by a message when he will check and save ..
         -----in this way designer can not leave any input or output that is connected to diode .....
       . ----- please provide a code to do it
  • SRNAYAK
    hi andrew,
    ---- that will search all input and output pin/ports of a schematic .. and then all pins/ports are conneced to an instance (antenna diode) or not ?
    I'm sorry, but I respond to posts in this forum in my spare time. Implementing this very specific check is nothing something I have already written, and nor is it something I have the bandwidth to do right now (I suspect it will need some back and forth to refine the specification if things are unclear).
    I'm sure that we (Cadence) would be happy to implement something like this for you as a service - please contact your account team (your sales executive, for example) who can discuss the requirement with you in more detail.
    Kind Regards,
