  3. Error mapping instances variables from schematic to layout...
  • Views 15848
Error mapping instances variables from schematic to layout using SKILL
TaherKotb
TaherKotb over 13 years ago
Hello
I made an interface which accepts from the user  transistors sizes to be mapped from a design schematic to layout. After entering values for these variables, the code mappes the intances names to their correct sizes. The issue i am dealing with is that the source, drain areas of the instances are not updated inside the schematic which generates an error when mapping the design to layout.
please find the script below:
CellSchId =dbOpenCellViewByType("test" "cell" "schematic" "schematic" "a")
deOpenCellView("test" "cell" "schematic" "schematic" list(list(0 0) list(500 500)) "r")
instIDM7=dbFindAnyInstByName(CellSchId "M7" )
instIDM7~>l=l7
instIDM7~>nf="2"
instIDM7~>w=w7
instIDM7~>wf=w7*nf
instIDM8=dbFindAnyInstByName(CellSchId "M8" )
instIDM8~>l=l7
instIDM8~>nf="2"
instIDM8~>w=w7
instIDM8~>wf=w7*nf
deOpenCellView("test" "cell" "layout" "maskLayout" list(list(0 0) list(2000 2000)) "r")
CellLayId =dbOpenCellViewByType("test" "cell" "layout" "maskLayout" "a")
;######################## END INSTANCES MAPPING ####################
lxGenFromSource(
CellSchId .........)
I tried to use desvar() but this didn't help either.
Thank you
Taher
  • skillUser
    skillUser over 13 years ago
    Hi Taher,
    When you change instance values using SKILL the CDF callbacks are not invoked; please see this solution article for calling the instance CDF callbacks from SKILL (after you have changed the parameter values), this should fix the issue.
    Lawrence.
  • TaherKotb
    Hello Lawrence
     Thanks very much for the reply. I have problem accessing this article, Can you please post it here ?
    Thanks again
    Taher
    Taher,
    There's an equivalent (slightly older) version of the code in this post.
  • TaherKotb
    Andrew,
    Thank you so much
