  3. set default setting for ruler in IC6/12
  • Views 2030
chrisn
chrisn over 13 years ago
Anyone know what i can put in my init file to set some default settings for ruler?
I don't want rulers as a savable object, snap target none and not selectable.
I have the follwing in my .cdsinit, but it's not working
leSetObjectSelectable("ruler" nil )
leCreateRulerForm->rulerTabs->page1->rulerSavable->value= nil
leCreateRulerForm->rulerTabs->page1->rulerSnapTarget->value="None"
When i paste the in my ciw, it does the trick
any ideas? (I'm using IC12)
Chris
  • skillUser
    skillUser over 13 years ago
     Hi Chris,
    This came up with another customer recently.  The command  leSetObjectSelectable("ruler" nil ) only works once the layer palette has been initialised (i.e. a layout is being displayed), and so it does not work in your .cdsinit.
    I developed the following workaround which should help you:
    procedure(CCFnoRulerFilter(obj)
       unless(obj~>objType=="ruler" t)
    leRegUserObjectSelectionFilter("CCFnoRulerFilter")
    This would be global for a session, so you might choose to activate this on/off with bindkeys (the filter can be removed by: leUnregUserObjectSelectionFilter() - there is no function to see if a filter is set or what the filter is, as far as I can tell).
    I filed CCR 1107225 for this problem, I suggest that you file a case with Customer Support and reference this CCR, requesting that it is fixed for you also - more requests allow R&D to know it is important for more than one customer, and they can prioritize accordingly.
    I hope this helps you!
    Lawrence.
  • skillUser
     Hi Chris,
    I missed the other two points,  there is a cdsenv environment variable to control each of the other two options:
    layout saveRulers boolean nil
    layout rulerSnapTarget cyclic "None"
    These can also be set through SKILL:
    leSetEnv("saveRulers" nil)
    leSetEnv("rulerSnapTarget" "None")
    Hopefully this answers your question completely now. These are documented in the IC616 release (and other releases for the saveRulers option, it was documented earlier than the snap target variable).
    Lawrence.
