  3. Alt bindkey modifer problems in layout session
  • Views 17469
psill000
psill000 over 13 years ago
Alt bindkey modifer problems in layout session:
I have  the environment variable set to use the Alt key and the hiBindKeyModifiers show I have the key as a modifier.
 envSetVal( "ui" "enableMenuShortcuts" 'boolean nil)
hiBindKeyModifiers()
("Shift" "Ctrl" "Alt" "Meta")
 Is there any other system settings or environment variables to from using the Alt bindkey?
    If you call  envSetVal( "ui" "enableMenuShortcuts" 'boolean nil) you get a popup as the attached picture shows. What this is telling you is that you need to actually set it via a .cdsenv file not using SKILL.
    Did you try that? Which version are you using? (type getVersion(t) in the CIW).
  • psill000
     Sorry I forgot to include the version.
    "sub-version  IC6.1.5-64b.500.15 "
    I dont get the pop up as you have pictured.
    I tried setting the variable in my cdsenv and loading the variable in the CIW.
    You won't get the popup if you've already set it to nil via a .cdsenv file.
    So what's not working? I just tried doing:
    hiSetBindKey("Layout" "Alt<Key>B" "println(23456)")
    and then I hit Alt-B in the layout, and it printed the number in the CIW. I tried ISR15, and it worked fine.
  • psill000
    The cadence session does not seem to recognize the bindkey.
    In other cadence environments I have used I did not have a problem, but something in the cadence session or system environment is preventing the Virtuoso from seeing the bindkey assignment.
    I tried dropping your bindkey example in the CIW, execute the bindkey and no print out, “2345”.
    I will have to see it is the wireless keyboard I am using not mapped correctly.
    What happens if you go into the BindKey UI (in Options->Bindkeys) and then try to add a bindkey? If you double click in the bindkey field on the right hand pane, you can hit the key combination (e.g. Alt-B) and see whether it enters the bindkey sequence or not.
    Did the accelerator keys work before you turned them off? Maybe your window manager is swallowing the Alt key bindings?
  • psill000
    The keyboard capture does recognized the Alt accelerator but not the Meta.
    The Virtuoso still does not execute any of the bindkey definitions with the Alt.
    I will try another keyboard.
