  3. How to write the code - menuItemCallbacks of hiCreateSimpleMenu...
  • Views 3487
How to write the code - menuItemCallbacks of hiCreateSimpleMenu ?
Charley Chen
Charley Chen over 13 years ago
 Dear All ,
I want to create a simple menu(hiCreateSimleMenu) ,
which arg l_menuItems  are fixed  , //A -> B -> C
each  A -> B -> C has it shape id // db:1111 db:2222 db:3333
How to let arg l_menuItemCallbacks follows  the l_menuItems correspondence ?
e.g.
if   choose A , it will select  db:1111
if   choose B , it will select  db:2222
if   choose C , it will select  db:3333
hiCreateSimpleMenu( 'test  "QQ"  list("A" "B" "C")  ????)
I don't know how to write ???  code  , How to do it ?
Thank you,
Charley
  • skillUser
    skillUser over 13 years ago
     Hi Charley,
    If I have understood your request correctly, it would be something like the following, assuming that the variables "A", "B" etc. contain the database ids of the appropriate instances:
    items = list(A B C)
    hiDisplayMenu(
      hiCreateSimpleMenu('CCFinstSelectMenu
        "Select Instances"
        foreach(mapcar item items item~>name)
        foreach(mapcar obj items
          sprintf(nil "geSelectFig(dbFindAnyInstByName(geGetEditCellView() %L))"
            obj~>name)
    I have attached an image of what this might look like - hopefully this is the sort of thing that you were looking for? (If you want "A", "B" etc. in the menu rather than the instance name, simply put the following as the first list passed to the menu function: list("A" "B" "C"), as in your example.
    Best regards,
    Lawrence.
  • Charley Chen
     Hi Lawrence ,
    Yes , You totally understanded my request.
    In fact ,  items maybe contains insts & shapes , so the code needs to add something ,
    e.g.  determin  whether is shape , if shape  select the shape , if instance , select the instance.
    But I don't know how to write . Could you help me ?
            obj~>name)
    Thank you,
    Charley
  • skillUser
    Hi Charley,
    Here is an attempt at what you are asking for - it may not work under all circumstances, I've arbitrarily picked the center of the objects' bounding box, but if there is an overlapping object this might pick the wrong object when performing the selection.
    hiDisplayMenu(
      hiCreateSimpleMenu(
        'CCFinstSelectMenu
        "Select Instances"
        '("A" "B" "C" "D" "E")
          case(obj~>objType
            ("inst"
              sprintf(nil
                obj~>name
            (t
              sprintf(nil
                "geSelectFig(gePointToFig(hiGetCurrentWindow() t %g:%g))"
                car(centerBox(obj~>bBox)) cadr(centerBox(obj~>bBox))
          ); case
        ); foreach
      ); hiCreateSimpleMenu
    ); hiDisplayMenu
    I tested this very briefly and it seems as though it should work.
    Best regards,
    Lawrence.
  • Charley Chen
     Hi Lawrence ,
    Thank you , But when has many shapes overlap , it won't work.
    (1)Can I write arg l_menuItemCallbacks as a function call ?
            sprintf(nil "TEST(obj)") //it wont work
    );foreach
    procedure( TEST(obj)
    printf("%L" obj)
    );pro
    (2)
    If select "A" ,  it has its dbId , How to pass its dbId
    If select "B" ,  it has its dbId , How to pass its dbId
    Thank you,
    Charley
    Fundamentally the limitation is that the callback has to be a string, and you can't represent a db object as a string (well, you can, but you can't then use that to locate the db object again, so that's not terribly helpful). It's not obvious how you are indicating to the user what the menu items are and how that relates to the db object underneath, but one solution would be to do this when you build the simple menu:
    MyGlobalItemTable=makeTable('dbLookup nil)
        sprintf(itemText "%L" obj)
        MyGlobalItemTable[itemText]=obj
        sprintf(nil "TEST(\"%L\")" obj) ; generate callback
    );foreach
    then in your callback function, you can do:
    procedure(TEST(objString)
      realObj=MyGlobalItemTable[objString]
      ... do whatever you want here
    Whatever you do, however, don't hang onto the contents of the global table for too long -  because the database ids might get invalid or recycled (e.g. if objects are deleted, or the containing cellView is purged). For the duration of a popup menu though, it's probably fine though.
  • Charley Chen
     Andrew,
     Thank you for help , I will try it.
    Charley
