  3. Virtuoso XL
  • Subscribers 150
  • Views 14642
Virtuoso XL
den408nis
den408nis over 13 years ago
I'm using XL in the IC6 version. After generating I generate the layout and make some connections I usually like to group certain devices and make them into a cell. The question I have is that is there a way to keep the connectivity in XL after I do that. From what I know once I make it into a cell the connectivity for those devices are gone.
Dennis
  • theopaone
    theopaone over 13 years ago
     What is the purpose of making these devices into a cell? Is it going to be re-used in other cells? You will have to add pins to the cell to connect through the hierarchy, I'm not sure on how to back annotate the schematic to define the corresponding instances as the components of a block.
    If you are only grouping them together to keep them together in this physical design, you can group them in a figGroup. Use the "Group" functions from the Create/Edit menu. All the elements in a figGroup act as if they were one element, moving, copying and deleteing together.
    Ted
