  3. String operations in skill
  • Subscribers 150
  • Views 22713
shazzy
shazzy over 13 years ago
Okay so we have a list 'p' constituting of elements as pin names.
 p = ("GIO<0>"  "G1E<1>"  "GAE2<2>"  "G3F1<3>")
And the task is to add the under-braces numeric value with 4 and convert this array into
  p = ("GIO<4>"  "G1E<5>"  "GAE2<6>"  "G3F1<7>")
I did these operations in perl and also bridged the gap between perl and skill.
But since this script has to be linked to a bind key hence I want to do the string operations in skill only.
Is there any skill code or so by which we can edit the numeric portion ( only under the braces) of the string and then return it back to the 'p' array?
  • dmay
    dmay over 13 years ago
    Here is one way to do it:
    p = list("GIO<0>"  "G1E<1>"  "GAE2<2>"  "G3F1<3>")
    procedure(myAdjustBit(nameList delta)
      let((newNameList parsed prefix suffix newSuffix newName)
        foreach(name nameList
            parsed=parseString(name "<>")
            prefix=car(parsed)
            suffix=evalstring(cadr(parsed))
            newSuffix=suffix+delta
            newName=sprintf(nil "%s<%d>" prefix newSuffix)
            newNameList = cons(newName newNameList)
        reverse(newNameList)
      ) ;let
    ) ;proc
    myAdjustBit(p 4)
    Derek
  • theopaone
    theopaone over 13 years ago
     Thanks, Derek. I had forgotten that parseString can take more than one parsing character
     Ted
