  3. Delete Property figs / wire in schematic
  • Subscribers 150
  • Views 17870
karacaoe
karacaoe over 13 years ago
Hello all,
How do you delete in Skill nets such that the wirings in your schematics are removed also?
There must be some sort of a simple solution for that!
Thank you so much in advance.
Best regards,
Oezlem
  • TaherKotb
    TaherKotb over 13 years ago
    Hello Oezlem
    You can do this for example;
    -get the schematic Id
    CellSchId= dbOpenCellViewByType( "Folded_Cascode" "Folded" "schematic" "schematic" "a" )
    -get the instance id which is connected to the wire you want to delete
    instM18 = dbFindAnyInstByName(CellSchId "M18")
    -get the ids' and names of the terminals connected of the instance
    instM18~>instTerms~>term
    (db:0x156c1c95 db:0x156c1c94 db:0x156c1c93 db:0x156c1c92)
    instM18~>instTerms~>term~>name
    ("D" "B" "G" "S")
    - get the net id for a specific terminal
    d_path = car(car(instM18~>instTerms~>term)~>pins)~>figs
    - delete command
    dbDeleteObject(car(d_path))
    Best Regards,
    Taher
  • TaherKotb
    Hey Oezlem
    I guess i was wrong concerning the dbDeleteObject command , it's not the right command to use
    instead please try this command
    d_path = car(car( instM50~>conns~>net~>figs) )
    schDelete( d_path )
    and it will delete the object you specified and in this case it will be  a wire
    Best Regards
  • karacaoe
     Hi Taher,
     Thank you so much!
     The command in your first reply deleted my pin ;)
    Best regards,
    Oezlem
