  3. Display text in layout window prompt line
  • Views 14982
TaherKotb
TaherKotb over 12 years ago
i need to display text in the prompt line of the layout window, i tried to do it as shown;
 procedure( tprompt
?prompts " point at the location to place M1  "
);end_procedure
 But instead, the text is printed in prompt line of CIW. What i am missing ?
 Thanks in advance
Best Regards
Taher
  • StefanSL
    StefanSL over 12 years ago
     Hi   Taher,
    i asked the same some time ago, have a look at my post
    http://www.cadence.com/Community/forums/p/17584/1247322.aspx
    --> setPrompts("my message" "")
    refer to sklangref
    hope this helps
    Stefan
  • TaherKotb
    Hi Stefan Thanks alot for the help, it works exactly the way i want. Best Regards
  • skillUser
    skillUser over 12 years ago
    Hi Taher,
    You may also want to look at or consider the "enter" functions that allow you to temporarily set the prompt during a command that gathers data - for example enterPoints, enterPath, enterPolygon...  Each of the enter functions accepts a ?prompts argument for this purpose.
    I hope that this helps you.
    regards,
    Lawrence.
  • TaherKotb
    Hello Lawrence,
     Thanks for your reply.
    I tried to look for a function to temporarily display the text in the prompt line just like the enter functions but i couldn't find one. My Case with different than in gathering data, i need to display the text between procedures so that only factor i am waiting for is for the code to exit executing certain procedure. So i used the setPrompts() inside if loops to solve temporary display issue.
     Best Regards
