  3. How to stream-out gds with via/pcell name get renamed with...
  • Subscribers 148
  • Views 2497
How to stream-out gds with via/pcell name get renamed with prefix only
kb how
kb how over 12 years ago
Hi.
Is there a way we can stream-out a cell and renamed only the via and pcell with prefixes? Currently virtuoso only allow us to rename the cell with prefix/suffix. Can we add prefix/suffix only for via and pcell during stream-out?
    Try looking for poParamCellNameMap in cdnshelp - this is the function you can define to map how pcells are named.
    I've not  tried this with vias, but according to this solution it should work.
    Kind Regards,
  • kb how
    Thanks Adrew.
    I found the solution which is using poParamCellNameMap (as as solution mention by you). Tested work.... YEAH! Thanks a lot.
    By the way, starting from IC615.ISR14, virtuoso added a new option for to rename -subMasterSeparator, this can be use to rename paramCell as well.
