  3. how to use skill function to create layout library with...
  • Views 18643
how to use skill function to create layout library with virtuoso tf file
tomchen
tomchen over 13 years ago
Hi
I use skill function like as bleow to create virtuoso tf libraryh ,and it works in 615_ISR12 , but fails in 5141.
And I also try to create library manually on gui , it can work on both 615 and 5141.
is there  other skill function  to create tf library??
following is my skill code:
tf_file = "./aaa.tf"
library_name = "aaa"
lib_id = dbCreateLib(library_name)
cds_tech=techOpenDefaultTechFile()
techCopyTechFile(cds_tech library_name "./" t)
tfId=techGetTechfIle(lib_id)
tcLoadtechFile(tfID tf_file)
techSaveTechFile(tfid)
    Try this instead:
    tfId=techOpenTechFile("aaa" techGetDefaultTechName() "a")
    tcLoadTechFile(tfId tf_file)
    techSaveTechFile(tfId)
    The way you tried it worked for me too - although I get some warnings in IC5141 about not being able to get an exclusive lock on the source library. But the way I suggest is simpler, I think - so maybe that's the best way to do it.
  • tomchen
    Hi Andrew: thanks your help it works well
