  3. Dim Major Dots in schematic
  • Views 17053
Aldo2
Aldo2 over 13 years ago
In Virtuoso Layout editor 6.1.5 it is possible to select the display option "Dim Major Dots", which seems to be missing for the schematic view. Is there a skill command that can do the same for schematic?
Thank you
Best regards
Aldo
    Hi Aldo,
    envSetVal("graphic" "dotStyleMajorGrid" 'boolean t)
    Kind Regards,
  • Aldo2
     I've seen that envSetVal("graphic" "dotStyleMajorGrid" 'boolean t) is only for schematic and symbol, whereas for layout envSetVal("layout" "dotStyleMajorGrid" 'boolean t) must be used
    Thank you very much
    Best regards
    Aldo
