  3. Get enterBox first/second coords
  • Views 1675
psill000
psill000 over 13 years ago
I would like to use the enterBox function to get box drawn, but I need to get the value of the first point of the box then the second point, not the box coords.
Is there a way to get the first point then the second point of the enterBox rather than bbox value?
    Isn't this lowerLeft() and upperRight() (or car() and cadr()) of the result of the enterBox?
    Or if you need the precise points that were digitized (rather than the lowerLeft and upperRight), use enterPoints() instead.
  • psill000
     You can start a enterBox from the lower right, upper left or the first point can be upper right. I would like to use the enterbox since it has the rubberband of the box. I will use enterpoint
