  3. Change parameters in pcDefinePCell code body
  • Views 15324
RVERP
RVERP over 13 years ago
Hi, I have a normal pcell that you can give certain parameters.  I want to check in this pcell if certain parameters are between a min and max value, and the reset the parameter to this value.  How is this done?
For now i tried a if else statement.
So I have parameter l, in the code body i check
if( l<minL then l = minL)
If I create an instance of this pcell, and enter a value lower as minL, this results in a pcell with correct l, only the value I initial entered is still visible in the instance parameters.
Can I change this?
Rik
  • skillUser
    skillUser over 13 years ago
     Hi Rik,
    This is a case where CDF callbacks can be used to good effect - the PCell parameter would have an associated CDF parameter, and this parameter would have a callback so that when the value is entered/changed on a form (Edit Object Properties, Add Instance) the value is checked within the boundaries that you set up; the CDF callback can modify (e.g. reset to min or max) the value to provide feedback to the user (along with a printed statement in the CIW, perhaps?)
    Search for CDF callbacks if you need more help, or post follow-on questions here.
    Hope this helps!
    Lawrence.
