  3. Create application form trigger??
  • Views 15253
tyanata
tyanata over 13 years ago
We want to create our custom button on on a certain predefined by some of our third party vendors Application form. It can easily be done with code like bellow:
      hiAddField(certainForm list(our_custom_button 200:600 200:25 140))
But the problem is that the form should be opened in order button to be added. So it will be best if some trigger could be set whenever the form is opened our button looading procedure to be executed.
Do you know if such kind of triggers exist?
tyanata
    No. You'll probably just need to call their code which is creating the form (presumably that's what you want). The trouble is that if the form is being created on the fly, this may not be possible.
    Best to contact the third party vendor and ask them if it is possible via a hook in their code?
  • tyanata
    Thanks for the repsonse!
    Actually the scripts of the third party vendor are not encrypted  so I know the SKILL file and the procedure where the Application form is being created.
    So the easiest thing is just to add my routine there, but I do not prefer that approach because each time when we update the third party software I have to place my hook there.
    I also could not just use the approach of setting a variable to their procedure and then again creating procedure with same name, placing in the beginning the variable, because originally the procedure is executed with autoload so may changes will be cancelled.
    So do you know if there is a way to detect when some procedure is run (the form creating procedure in the case ) and in that moment my code to be triggerred.
    Best regards,
    tyanata
