  3. accessing db and executing SKILL from the Unix shell
  • Views 18808
jaleco
jaleco over 13 years ago
I am trying to run some skill code to access db information from a bash script, but cannot get the script to run successfully.  Can anyone describe the proper way to perform a simple db access from a shell?
My attempt was somthing like this:
#!/bin/bash
./start_cadence_virtuoso -nograph < find_coords.il
(or alternatively include the skill code in the bash script, but neither format seems to work)
A simple find_coords.il skill script might look like this:
cv=dbOpenCellViewByType("mylib" "mycell" "layout")
foreach( inst cv~>instances
if(inst~>cellName == "specific_cell" then
printf("%L\n" inst~>xy) ; this would be printed to an output file or as needed once the script was functional
); if
); foreach
dbClose(cv)
exit
  • skillUser
    skillUser over 13 years ago
    You can use "dbAccess" if you only need to use database level functions (i.e. no sch.* or le.* etc.) and you can use the -load argument to load and run a SKILL script.  By the way, dbAccess is now documented, albeit a little lightly, in ISR17 of IC615 and other recent releases.  It is similar to running virtuoso -nograph but has a smaller footprint since it only contains core SKILL plus db functions (similar to the SKILL that is supported for use in PCells).
    Hopefully this is what you are looking for?
    Best regards,
    Lawrence.
  • skillUser
    Forgot to mention that "virtuoso" supports the -load and -replay command line options.
    Lawrence.
  • jaleco
    Thanks for your response Lawrence,
    I am using v5.1.41.
    Can you provide me an example?  Finder does not come up with anything for dbAccess...
  • jaleco
    Ok, I got it to work from the command line -
    dbAccess -load myfile.il
    I was thinking that dbAccess was a skill command!
    Thanks again
