  3. Skill Code to Create Guard Ring
  • Replies 9
  • Subscribers 153
  • Views 25426
Carlsberg
Carlsberg over 13 years ago
Hello
I am looking for a skill code to create guard ring automatically !The tool I am using is virtuoso !
In the new vision of IC5141,this operation was contained
But the vision of IC5141 I am using is the old vision
So  please help me!
Thanks!
     As far as I know, the functionality related to guard rings and multi-part paths is the same in all IC5141 versions. You can create multi-part paths with SKILL using rodCreatePath - and you could use this solution which provides a SKILL way to draw a multi-part path using a template that you've defined in your tech file.
  • Carlsberg
    Thank you!
     The functionality I want to operate by skill code is just like one of  functionalities in  the tool  which is called  Layout  Turbo.
    The functionality in this tool can automatically creat guard ring when I select  some mos.
    I wonder  if there are some skill codes perform like that .
    could you provide me some samples?
    Thank you very much
     What's wrong with Create->MPP Guard Ring? There's also Create->Fluid Guard Ring. The Turbo toolbox functionality is still available too if you need that.
  • San
    San over 11 years ago
    I am not sure if I need to create new post for this. Let me know if this is not the place to post this here.
    How to follow  create-> MPP guard ring  using SKILL in non-interactive mode ? (In GUI mode it asks to select the bBox and place it around instance). Also how to edit Net name parameter within that form. Please guide.
    Sanket
    Sanket,
    If you'd read the forum guidelines you'd have seen that you should have posted a new thread. However, there isn't any procedural interface to create guard rings. Your best bet would be to write something yourself using the SKILL code I mentioned earlier in this thread which can create an MPP given an existing MPP template and a list of points - you'd just have to generate the list of points yourself (a simple piece of SKILL code)
  • San
    This solved my problem I have been trying since last 2 days. Thanks a lot Andrew ! I appreciate you suggestions.
  • James Yam
    James Yam over 6 years ago in reply to Andrew Beckett
    So, could I use the same solution (CCSdrawMPPUsingTemplate.ils) here to create the fluid guard ring? Any modification I needed to have? I found techGetMPPTemplateByName got nil.
    If no, what command should I use?
    Remark: I am using IC615 or later.
    Thanks!
    Andrew Beckett over 6 years ago in reply to James Yam
    No, you can't use this code to create a fluid guard ring instance, or even a modification of it. A fluid guard ring is a totally different thing to a multi-part path. It's a PCell with special parameters.
    I've not really looked into creating fluid guard ring instances using SKILL - yes, they're an instance, but I'm not sure if there's an easier way to handle the special parameters that the FGR takes. So I would suggest contacting customer support as I certainly don't have time to look into this right now (the day job is keeping me pretty busy).
  • James Yam
    Thanks Andrew!
    You have already given a big hints to me.
    Thank you!
