  3. How to find value of viaCutClass param?
  • Subscribers 150
  • Views 15400
egolowen
egolowen over 12 years ago
I have been unable to figure out how to find the cutClass of a VIA - I have been able to find cutRows/cutColumns and everything else I need but am not sure where the value of cutClass is stored.
Any help would be appreciated.
Elizabeth
  • psill000
    psill000 over 12 years ago
    I quit looking for the variable and use the height and width values to determine the via type.
    ~>cutHeight and ~>cutWidth
    Hi Elizabeth,
    It doesn't store the cutClass - for example, the edit properties form uses a lookup based on the parameters of the via and sees if it matches the cutClass definitions.
    There is a section in the documentation entitled  Accessing cutClass information using SKILL - you should be able to search for this in cdnshelp - although you'll have to do the lookup yourself if you want to find the match.
