  3. Blockage with type "viaRouting" not visible in Virtuoso...
  • Views 2201
Blockage with type "viaRouting" not visible in Virtuoso Layout
kb how
kb how over 12 years ago
By reading from Cadence Documentation, noticed that dbCreateLayerBlockage, the function actually support blockage type "viaRouting", but "viaRouting" is not available in Create->Blockage Object->Blockage Type list.
When i created blockage and specify the type to "viaRouting". The blockage is created successfully with return blockage_id but the blockage is not able the see in layout (invisible in layout view).
dbCreateLayerBlockage(geGetEditCellView() "VIA2" "viaRouting" list(0:0 0:2 2:2 2:0))
My question is:
1. Is blockage with "viaRouting" type supported in Virtuoso?
2. Is YES, how can i enable the visibility of this blockage type? How to add viaRouting in Blockage Type list?
 Thanks in advance.
  • berndfi
    berndfi over 12 years ago
    It is under the "Object Assitance" dock, "Blockages -> Routing Blockage" and there your vias should be listed.
  • kb how
    Thanks.
    But the routing type is "routing" not "viaRouting"
