  3. Is it possible to add a new tab to an existing tab fiel...
  • Views 2474
Is it possible to add a new tab to an existing tab field
FrncsJRClement
FrncsJRClement over 12 years ago
 Does anyone know whether it is possible to add a new tab page to an existing tab field?
Could find an answer neither in skuiref.pdf, nor on this forum.
Here is what was tried to no avail:
1) Initial form creation:
Code example (stored in file "tabTest.il"):
 procedure( cwsFx(x_pageNumber)
  hiCreateFloatField(
    ?name       concat('float_ x_pageNumber)
    ?prompt     "Scaling"
    ?value      1.0
    ?range      '(1e-30 1e30)
) ; procecure cwsFx
let( (tabField)
  unless( boundp('CWSTestForm)
    tabField = hiCreateTabField(
      ?name     'CWSTestTab
      ?fields   list(
                  list(
                    list( cwsFx(1) 0:0 400:30 80 )
                  list(
                    list( cwsFx(2) 0:0 400:30 80 )
    ) ; hiCreateTabField
    CWSTestForm = hiCreateAppForm(
      ?name             'CWSTestForm
      ?formTitle        "CWS Test Form"
      ?fields           list(
                          list(tabField 0:0 600:200)
      ?dontBlock        t
    ) ; hiCreateAppForm
    hiInstantiateForm(CWSTestForm)
  ) ; unless boundp CWSTestForm
  hiDisplayForm(CWSTestForm)
  printf("form handle is CWSTestForm\n")
  printf("CWSTestForm->CWSTestTab->page1->fieldType is '%L'.\n" CWSTestForm->CWSTestTab->page1->fieldType)
) ; let
Execution in CIW:
load("tabTest.il")
Result:
CWSTestForm->CWSTestTab->page1->fieldType is 'scrollRegion'.
t
2) Attempt #1:
Code example:
procedure( addTabPageAttempt1()
  let( (pageCount newPageNumber newPageSymbol newPage)
    pageCount = if( listp(CWSTestForm->CWSTestTab->fieldList) length(CWSTestForm->CWSTestTab->fieldList) 1)
    newPageNumber = add1(pageCount)
    newPageSymbol = concat('page newPageNumber)
    newPage = hiCreateScrollRegion(
      ?name       newPageSymbol
      ?fields     list(
                    list( cwsFx(newPageNumber) 0:0 400:30 80 )
    ) ; hiCreateScrollRegion
    putprop(CWSTestForm->CWSTestTab newPage newPageSymbol)
    if( pageCount > 1
    then
      append(CWSTestForm->CWSTestTab->fieldList list(newPage))
    else
      CWSTestForm->CWSTestTab->fieldList = list(CWSTestForm->CWSTestTab->fieldList newPage)
    ) ; if pageCount > 1
    hiDisplayForm(CWSTestForm) ; form refresh
  ) ; let
) ; procedure addTabPageAttempt1
Execution in CIW:
Result:
 t (no change in displayed form...)
3) Attempt #2:
Code example:
procedure( addTabPageAttempt2()
    pageCount = if( listp(CWSTestForm->CWSTestTabNumber) length(CWSTestForm->CWSTestTabNumber) 1)
      ?name       newPageSymbol
      ?fields     list(
    hiAddField(CWSTestForm->CWSTestTab newPage)
  ) ; let
) ; procedure addTabPageAttempt2
Execution in CIW:
Result:
*WARNING* Illegal 2D field description:
*WARNING* scrollRegionStruct@0x15a05980
*WARNING* hiAddField: invalid 2D field description
Many thanks for your help
  • TaherKotb
    TaherKotb over 12 years ago
    Have you checked the status of the tab field ?, it may be disabled.
    To enable the entire field:
    form->tabField->enabled = t
    To enable a specific page of the tab field:
    form->tabField->page->enabled = t
    Hope that helps
    Best regards
    Taher
    There's no mechanism for doing this right now - tab pages cannot be added (or removed) dynamically other than enabling or disabling them dynamically.
    The alternative is to recreate the tab field completely, adding a new page on, and then replace the original tab field on the form. That would be easy enough to implement.
