  3. Error when importing outputs into ADE-XL using OCEAN
  • Views 15872
hapn
hapn over 12 years ago
I'm trying to import some expressions into ADE-XL test environment using OCEAN. I created a SKILL file (foo.il) with the following:
 session1 = axlCreateSession("foo")
 handle1 = axlSetMainSetupDB(session1 "./data.sdb")
 print "About to import outputs..."
 axlOutputsImportFromFile(session1 "./outputs.csv" ?operation "overwrite")
 axlSaveSetup()
 exit
Then I run ocean (6.1.6.500.2) using ocean < foo.il
 Here's what I get:
 ocean> "About to import outputs..."nil
 ocean> *Error* asiGet: no applicable method for the class - list(symbol)
If I invoke ocean in the interactive mode and  enter the above command, it works fine.
Any help will be appreciated!
hpan.
    If I do this (in IC616 ISR4, at least):
    sess = axlCreateSession(getCurrentTime())
    axlSetMainSetupDBLCV(sess "mylib" "ampTest" "adexl")
    axlOutputsImportFromFile(sess "outputs.csv" ?operation "overwrite")
    Then it works fine, even without a window open.
    I also tried what you did (the data.sdb didn't exist, so it was a bit silly) - for me it "works" (although it complains that it couldn't import the output because it didn't know anything about the test or the signal involved.
  • hapn
     Thanks a lot for reply and help.
     I think I got the error because I did not invoke the ocean in the design root.
    Thank you very much again and Merry Christmas :)
    Best,
    Haiyang
